Old 12-15-2018, 07:56 PM
68Malibu383 68Malibu383 is offline
Default How long might Wilwood Rear rotors last...
On a 3,500 lb car that will see 3-4 track events per year at VIR and a few autocross events? Prior owner installed these but it may be cheaper to convert to C5/C6 rear brakes since the cost per rotor is about $175 less than Willwoods.
Old 12-16-2018, 06:02 AM
Tinker's Avatar
Tinker Tinker is offline
Which Wildwood rotors? What diameter? What pads?What are the front brakes? Do you have a properly adjusted proportioning valve? Brakes need to function as a complete system. IMHO seems rear rotor wear should be one of the last issues to plague a brake system.
Chris
Old 12-16-2018, 08:31 AM
I don't have the part numbers as prior owner no longer had receipts. I contacted Willwood and they told me where to find part numbers, so I'll work on that. Best guess is they are Dynalite with unknown pads and the rotors are 12.19"
Fronts are Willwood but I"m going to replace those with the Kore3 14" C6 kit.
Old 12-17-2018, 09:02 AM
Turbo6inKY Turbo6inKY is offline
This guy.
I've got two years on a set of 11" rear rotors on my car, 15 track events. Replaced the fronts once already and turned the rears when I replaced the fronts.
But your mileage will definitely vary.
Andrew Scott
1987 Buick Grand National
Web Log
Instagram
Youtube
Old 12-17-2018, 05:19 PM
Tinker's Avatar
Andrew, I just read your web log on your rear brakes. Very nicely written and very informative. You did an excellent job on it.
Chris
The Following User Says Thank You to Tinker For This Useful Post:
Turbo6inKY (12-17-2018)
Old 12-17-2018, 07:39 PM
Thanks! I hope others can learn from my pain.
Andrew Scott
Web Log
Instagram
Youtube
Old 04-15-2019, 06:23 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I know this is an older thread but I had custom rotors made for less than the stock Wilwood GT rotors.
http://www.colemanracing.com/Custom-...ild-It-W9.aspx
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 04-15-2019, 10:11 PM
Build-It-Break-it's Avatar
What was the cost per rotor at Coleman Steve? I know prices change all the time but just curious.
Ahmad B
Old 07-09-2019, 08:42 PM
TheJDMan's Avatar
It has been about 8 years since I assembled the brake system but as I recall the closest spec Willwood GT rotor I needed was just a little over $200ea and would still have required some additional machine work to fit my Moser floater rear end hubs. The Coleman custom rotors were around $120ea as I recall and I was able to spec them exactly as I needed them.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
