Old 12-27-2018, 06:39 PM
darkostoj's Avatar
darkostoj darkostoj is offline
Default Building a Full Floater 9" axle with negative camber
Hey all, looking at building a new rear axle for my road race car.
Doing a 9" with full floating axles. I have heard about methods of using special axle shafts for be able to get negative camber.
Anybody have any recommendations? I bought a blank axle and was going to weld the full floater ends on it. Since I'm going through the trouble of doing that, dialing in some negative camber would be pretty slick!
Old 12-27-2018, 07:00 PM
Musclerodz's Avatar
Talk with speedway engineering and or JCG.
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-27-2018, 07:02 PM
darkostoj's Avatar
What is JCG?
Old 12-27-2018, 08:43 PM
Musclerodz's Avatar
What is JCG?
JCG Customs in CA. Chris Gonzales is a member here.
Mike Redpath
facebook page
Old 12-28-2018, 04:27 PM
Tony at abcperformance.net developed a kit and has exclusive rights I believe for the next little bit then it goes to strange . Either way hes got the goods you need
Old 12-28-2018, 09:23 PM
craig510's Avatar
craig510 craig510 is offline
There are special snouts and crowned axles that are needed to make it work. Some circle track suppliers have them. eBay is a good place for takeoffs but you need to be careful to get exactly the right snouts and hubs and axles and drive flanges. Easy way is to just order one from winters or speedway engineering.
Old 01-02-2019, 02:59 PM
z28cp z28cp is offline
You can get weld-on or bolt-on cambered snouts in different degrees. Then you just need cambered drive plates.
https://lefthanderchassis.com/v2a/16...idcategory=408
DaveZ.
CP29
There is no such thing as too much power, or too much tire!
