Old 08-27-2006, 07:45 PM
RickM415 RickM415 is offline
Default v band seals or gaskets anyone ?
whats the best way to get them to seal completly ? is there like a gasket for sale out there ? i searched and no results
Old 08-28-2006, 01:35 AM
victionone victionone is offline
No gaskets. Just tighten the clamp while making sure both sides are positioned right and the flanges are flushed.
Old 09-11-2006, 08:18 PM
cadpro cadpro is offline
No gaskets. Some models actually have the tube slide into the opposing section by .250" to help it register correctly. Others have a register built in.
http://www.cardomain.com/ride/2389193
'66 Chevy II Wagon (construction to begin soon!)
'60 VW Bug, Ragtop
'03 Subaru WRX
'05 Saturn VUE
Does the name Pavlov ring a bell?
Old 09-12-2006, 02:58 PM
69 L88 Camaro 69 L88 Camaro is offline
Default Marmon Flanges
I use alot of those connections here at work, Detroit Diesel. I tap the flat part of the clamp all the way around with a hammer and then retighten the clamp. I usually get excellent results. You may want to try holding a large hammer on one side and tap with a small mechanics size on the other. I am guessing you already have this system built and it is leaking. cadpros's suggestion is the way we always build them. Alot easier to assemble also. Good luck
