Old 01-15-2019, 06:11 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Default L99 with external oil cooler question....
I'm swapping a '14 Camaro L99/6L90 into my wifes FJ40. The L99 has the external oil cooler on the side of the oil pan and plumbed into the cooling system.
Are you guys keeping the oil cooler on your swaps? How are you plumbing the coolant feed into the cooler?
Jeff-
Old 01-15-2019, 09:01 PM
JKnight JKnight is offline
Basing my opinion purely off my experience with my POS 6.0L Ford Diesel, I would eliminate it and run a stand-alone oil cooler. I’ve found the oil cooler can break down due to acidity in the coolant, and when it does, you end up with oil in your coolant. May only be a stupid Ford problem, but that’s my experience.
Old 01-15-2019, 09:11 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Jeff I run the oil coolers from 2006-13 Z06 corvettes, run them to a small cooler mounted up front. Its air to oil and easy to mount.
Old 01-16-2019, 05:28 AM
Ketzer's Avatar
Thanks for the tips guys!
Keeping a factory system in place has its appeal, but not if it’s going to be problematic down the road.
Jeff-
Old 01-16-2019, 06:42 AM
dhutton dhutton is offline
Jeff-
There are Camaros with 100k miles on them using that system. No reason to think there will be problems imho.
Don
Old 01-16-2019, 08:04 AM
Ketzer's Avatar
Don
True!
One of my issues is I may have to swap oil pans and this factory setup bolts to it. Wanted some experienced opinions to guide my choices. Nothing seems too complicated either way I go, but I do have a bad habit of over thinking....
Jeff-
Old 01-17-2019, 04:49 AM
rickpaw rickpaw is offline
Jeff, do you have a build thread somewhere on the FJ? I picked up a 74 FJ40 and I'm in a middle of stripping it down/selling off parts I don't need. Hoping to get it going before summer.
Tu Ho
Old 01-17-2019, 06:27 AM
Ketzer's Avatar
https://lateral-g.net/forums/showthread.php?t=54846
I'm in the strip down, mock up stage on the LS conversion right now. Once I begin to get some things sorted out, i'll update the thread with some pics...
Jeff-
