Old 01-17-2019, 03:39 PM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default miniMAX power hammer by ProLine
We show you the ProLine miniMAX power hammer. In this video you'll see the features that make it a unique metal shaping machine capable of a large range of metal shaping tasks. Click the link below to see this machine on our website, Trick-Tools.com.
https://www.trick-tools.com/ProLine-...luxe-Kit-11531
The mini-Max is a fifth generation design by well known and respected metalshaper Loren Richards. ProLine has taken this design and built a machine that performs like a Pullmax reciprocating machine, only in a much smaller and portable version. Features include a variable speed foot pedal control, quick change tooling, and a cam action upper die holder to allow for easy placement and removal of the work piece.
The mini-Max can shrink, stretch, dome, edge turn, bead, offset — it is limited only to your imagination. It's the perfect compliment to any Planishing Hammer or English Wheel. See our variety of ProLine tooling under the accessories tab to make this machine even more flexible.
The mini-Max uses 16mm square shank Pullmax tooling.
Warranty:
1 year manufacturer's warranty
Specs:
•Throat Height (inches): 9
•Throat Depth (inches): 18
•Steel Capacity: 16 gauge
•Strokes per Minute: 1150 max
•Motor: 110 volt, 3/4 hp
•Weight (pounds): 360
•Dimensions (LxWxH): 34 x 29 x 70
Includes:
Variable speed Mini-Max
Foot pedal control
Stand with die storage and wheel kit
Thumbnail shrinking dies
Straight fence
Contour fence
Wrenches and user manual
Accessories:
https://www.trick-tools.com/Pullmax-...tal-Shaping-59
Brycen Smith
[SIGPIC][/SIGPIC]
