Old 02-18-2019, 09:05 AM
darkostoj's Avatar
darkostoj darkostoj is offline
Default Using a manual steering box for a race only setup
Hey guys, got a 2nd gen camaro front subframe in my Rolls Royce race car and wanted to ditch the hyd power steering pump.
I started looking into electric assist on the steering column and realized I would still have to address the steering box, I could either plug the ports and not run a pump or get a manual box. Then I got thinking into running a manual only box. I am new to racing so, not sure if that's even an option.
I have never used a manual steering box racing before, but I really like the idea of simplicity, less parts, lighter, more reliable, etc.
The car races in a 24 hour endurance race so reliability is really important.
The last race I lost power steering and the car was really hard to steer, want to avoid something like that from happening again.
Is running a manual box even worth considering? (I do have a small 13" steering wheel)
Old 02-18-2019, 09:38 AM
ur-n-8 ur-n-8 is offline
The manual box’s are a lot slower, either 4 or 4.5 turns lock to lock if I remember right.
Old 02-18-2019, 10:41 AM
darkostoj's Avatar
Is it better to have a 12.7:1 or a 16:1 ratio box on the track?
Old 02-18-2019, 01:30 PM
JKnight JKnight is offline
I’d be concerned about wearing out your drivers in an endurance setting. Manual boxes aren’t as bad at speed, but I would think with wide front tires and hours long stints, you’ll get “arm pump” pretty bad, to use a motocross term.
I had a Remy Racing manual box on my car and found the it pretty tiring on the canyon runs I did. This was 7 years ago in my late twenties when I still had “hockey strength”.
Old 02-26-2019, 11:20 PM
David Pozzi's Avatar
some manual first gen Camaros have 6 turns lock to lock. you don't want to be turning your steering wheel a complete revolution to enter a turn on a road course.
You don't want to just plug the power steering box. The piston inside will make it very hard to steer. At least make a loop of hose from inlet to outlet & remove some of the oil. The stock box is probably 17:1 ratio, but there are two lengths of pitman arms and three lengths of outer steering arms on the spindle that determine the overall ratio.
There is a 16:1 manual box available. https://www.rickscamaros.com/camaro-...1967-1969.html
There may be faster ratio manual boxes available around 14:1.
The stock power steering isn't hard to keep alive, the main thing is to use a cooler in the return line.
http://www.PozziRacing.com
Old 02-27-2019, 08:05 AM
andrewb70's Avatar
Check out DCE Motorsport for race oriented EPAS systems.
http://www.dcemotorsport.com/Home/EPAS
Andrew
Instagram @dr__efi
I offer remote Holley EFI tuning.
I deliver what EFI promises.
Please get in touch if I can be of service.
My YouTube Channel
Old 02-28-2019, 03:39 PM
gerno's Avatar
gerno gerno is offline
We run a friends fairly light V8 Opel in WRL with factory manual steering and 255 200TW tires. The car has to be man handled for sure and wears your out after a 2 hour stint. I assume the Rolls would be a much heavier car and necessitate much more steering effort with a manual box. Without knowing your car I'd still recommend sorting out the PS. From my experience comfort is pretty important when running endurance stuff
