Old 02-25-2019, 06:42 AM
NickBurns NickBurns is offline
Default Wire loom
Favorite wireloom for the engine compartment? Tried using PSI’s the larger stuff separates on corners.... painless?
Thank You !!!
Nick's son was last seen finishing up his 1968 Pro Touring Camaro
1968 Pro touring Camaro
ALL DSE Suspension
2017 6.2L made of steel balls
Old 02-25-2019, 07:00 PM
Gmachine1911's Avatar
Gmachine1911 Gmachine1911 is offline
I started out using the Painless fabric loom and it's great stuff but pretty pricey. I found the Summit brand fabric loom to be half the price and just as good. They sell a tool to help lay the wire inside the loom and I would recommend getting one for the smaller diameter stuff...it's a complete PITA to work with but the finished product is well worth it.
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
Old 02-25-2019, 07:44 PM
Check amazon if you can’t find it will send link
The Following User Says Thank You to XLexusTech For This Useful Post:
NickBurns (02-26-2019)
Old 02-25-2019, 07:54 PM
Have you tried the techflex ? This is the stuff I tried to use? I don’t mind spending extra if when there are bends in the harness the 25% overlap doesn’t bulge out ...
Thanks for answering !
ALL DSE Suspension
Old 02-25-2019, 08:22 PM
ALL DSE Suspension
Old 02-25-2019, 08:31 PM
I ended up with some techflex on one of the components I bought and threw it away. It's junk compared to the fabric loom and looks cheap to me. The ends fray and when you try to melt them with a heat gun or lighter to stop the fraying, it just melts together. The fabric loom has aprox 25% overlap as well, that's why it's such a pain to work with (especially the small diameter stuff). It bends easily and doesn't allow the wiring to come out. Plus when you cut it, just melt the end a little and you have a nice, crisp edge. If you buy a roll, you won't go back and you won't be sorry.
Shane
#theanchorholds
Old 02-26-2019, 06:54 AM
Thank you!!! I was thinking it was just me !!!
ALL DSE Suspension
Old 02-26-2019, 07:17 AM
ironworks's Avatar
This tool gets rid of the frayed ends.
https://www.amazon.com/TECHFLEX-HKB0...96184256&psc=1
The Following User Says Thank You to ironworks For This Useful Post:
Old 02-26-2019, 08:30 PM
Musclerodz's Avatar
I like to use heat shrink when building looms from scratch. If I use techflex, I will either use heat shrink on the ends or a chemical tape that once activated its takes a razor blade to get it off. I have also wrapped looms in electrical tape for more factory look. It all depends on the job and budget.
Mike Redpath
Musclerodz & Customz
facebook page
The Following User Says Thank You to Musclerodz For This Useful Post:
Old 02-26-2019, 09:04 PM
eville's Avatar
eville eville is offline
Thanks, just scored a NIB one on ebay for $75
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
