Old 02-27-2019, 09:34 AM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default Rhino Cart Welding/Fixturing Table
Rhino Cart welding and fixturing table available at Trick-Tools.com
The 48 x 30 inch Rhino Mobile Fixturing Station is unlike any welding cart on the market! This revolutionary design takes the popular BuildPro welding table top, with it's precision finish and unique modular fixturing design, and combines it with a handy mobile cart. The nitride treated steel top features a black oxide finish and is reversible if one side is damaged.
The package comes complete with a 66 piece fixturing kit and the cart features heavy duty casters as well as leveling feet for more permanent placement. The 36 inch tall cart features plenty of storage shelves to keep necessary fabrication tools readily at hand.
https://www.trick-tools.com/StrongHa...54830-K1-10380
Table Top Specifications
Hole diameter: .625 +.001/+.003
Hole spacing: 2.000 +/- .002
Plate thickness: .625
Warranty:
1 year manufacturer's warranty
Specs:
•Capacity: 1500 lbs
•Size: 48 x 30 inches
•Finish: Nitrided
•Hole diameter: .625 inch
•Hole spacing: 2.000 inches
•Plate thickness: .625 inch
•Weight (pounds): 470
•Dimensions (LxWxH): 48 x 30 x 36
Includes:
48 x 30 x 36 inch tall fixturing cart with casters, leveling feet, and storage
(10) Adjustable Lock Bolts, T55055
(2)Locating Pins, T54201
(2) 2.3 inch Inserta Pliers, PTT522K
(2) 4 inch Inserta Pliers, PTT634K
(2) Inserta Clamps, UDN5150
(2) Inserta Clamp Top V-Pads, T54217
(2) Side Clamps, TCX5210
(4) 2 inch Locate Stops, T54205
(4) 1.5 inch Locate Stops, T54203
(8) V-Block, T54216
(4) V-Block Spacers, T54211
(8) D-Stop Bars, T50632-01
(12) Magnetic Rest Spacers, T50737
(2) 2 inch Right Angle Brackets, T50304
(2) 4 inch Right Angle Brackets, T50305
Accessories:
Fixturing- https://www.trick-tools.com/Table_Cl...ccessories_750
Receiver Mounts- https://www.trick-tools.com/Vise-and...RM-Combo-13239
Notcher- https://www.trick-tools.com/Buildpro...r-ATN100-11937
Plasma Cutting Tray- https://www.trick-tools.com/TPL3021-...ino-Cart-12951
Brycen Smith
[SIGPIC][/SIGPIC]
