Old 08-29-2006, 10:24 AM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
Default Floor pan removal
I'm ready to cut and replace both the front floor pans in my 67. The car is sitting on the rotesserie now, is there any need for additional support? I'm planning on doing one side at a time and leaving the majority of the trans tunnel in place. Any advice from those of you that have done this?
Old 08-29-2006, 03:51 PM
ahowudoin ahowudoin is offline
Why didn't you just get the whole floor pan?
Old 08-30-2006, 06:25 AM
fladoans fladoans is offline
If it's a Conv - most people say to brace it, if it's a coupe you can do it without bracing as long as the rockers are solid. I did my coupe on a rotisserie and since I cut the entire floor out I braced it just in case. I suppose the rcokers will support the body, but why take chances.
Steve
69 Camaro
Old 08-30-2006, 07:46 AM
Jay Hilliard's Avatar
Braces, braces, braces. You will be sorry and upset if you dont when you measure and it is tweaked or worse.
Just my 2 cents.
Jay
Old 08-30-2006, 02:27 PM
Ok, sounds like braces, The headliner is still in it, so I guess I'll have to pull that out first. The rockers are new, and all the underlying metal was good when I pulled them, and the trunk pan is new. How and where would you brace it? It's a coupe not a vert. Is it better to sit it back on the jackstands before cutting? Soon as I have something other than a shell, I'll post some more pics. Not to much to look at right at the moment.
Old 03-25-2007, 10:04 PM
67 Builder 67 Builder is offline
I am also getting ready to in stall a full floor pan. I was planning on setting it on jack stands. I am planning on using sqaure tubing and running two of them from rocker panel to rocker. One towards the front and one on the back through the inside of the car. Does this sound right? any thing else to be aware of?
thanks for the replys
Old 04-11-2007, 01:46 AM
Bandit Ls-1 Bandit Ls-1 is offline
this is an old thread.... but if any1 is still wondering the way to brace it is weld square tubing inside in the REAR from left to right by where the rear armrest's would be, and then in the FRONT under the dash from left to right where the kick panels are,for the SIDES if the doors are unbolted weld in the tubing from front to rear in the door jamb area on both sides, if the doors r still on just weld the tubing to the braces that are on the front and rear. for extra assurance weld an X from the driver front kickpanel area to the pass. rear armrest area and then do the same for the other side.
1979 Trans-Am Ls1 project
1972 Chevelle 454
Old 04-14-2007, 07:30 AM
TPC's Avatar
TPC TPC is offline
Bandit has it right, brace it bigtime. it s a lot easier to spend the time now bracing, than bending your door later to fit in the opening
