Old 03-02-2019, 11:08 AM
prolificdesigns prolificdesigns is offline
Default Ford SBF 302 Efi with coil on plug
I’m looking at doing holley hp Efi kit on a ford sbf 302 in a 65 mustang. I also want to change it over to coil on plug and run LS coils on it so I can hide them on frame. What is best holley wiring kit I’ll need. To make this work seamless on a SBF. Just wanted to see if anybody has done this and if so if they have any tips.
The Following User Says Thank You to prolificdesigns For This Useful Post:
vthornhill (05-02-2019)
Old 03-08-2019, 12:51 PM
novahollic's Avatar
novahollic novahollic is offline
I don't think you're going to find a plug an play kit for that.
Best I could find is using harness 558-307 to add the correct wires to your harness, and then 558-321 to plug into the LS coils.
Not the easiest thing, but doable with some wiring know how.
The Following User Says Thank You to novahollic For This Useful Post:
prolificdesigns (03-09-2019)
Old 03-09-2019, 03:09 PM
Thanks I don’t mind doing a little wiring, will I need to pair that with 558-105 and just make a complete custom harness, or is there another main hardness that would be easier?
Old 03-11-2019, 11:16 AM
novahollic's Avatar
Ah, my mistake. I thought you already had the HP efi in the car and you wanted to convert it.
If you're starting from scratch, get harness 558-118. That has the coil on plug harness already built into the main harness. Then you just plug the LS coil harness, 558-321, into that. Much easier.
You may want to contact Holley just to double check my info, but I've done a lot of these systems and it should be that simple.
Old 05-02-2019, 05:37 PM
vthornhill vthornhill is offline
Please let us know how it went....I'm a little ways away from doing the same thing to my SBF. I was looking at the Holley HP/Edelbrock Victor multi port manifold/MDS plug dist.
