Old 03-31-2019, 09:37 PM
Perry Mitchell Perry Mitchell is offline
Default radiator hoses
Does anyone on this site have connections with a supplier for molded radiator hoses? I need an upper radiator hose for my 67 Camaro project that is powered with a Corvette LT5 engine, I want a smooth rubber molded hose like the one pictured only it needs to be 2" longer on each end. The radiator end needs to be 1 1/2'' while the lower end should be 1 3/8'', although I can make 1 1/2 '' work for both ends. I have been to the local parts stores and looked at all the hoses hanging from their rafters but the one I have is the closest one I've found. It is a NAPA hose # 7266 . Any advice or help? I don't want braided stainless steel or corrugated stainless steel. I have been looking for years!
Old 04-10-2019, 06:57 PM
F'in mine's Avatar
F'in mine F'in mine is offline
You could try this link.
http://www.daycoproducts.com/online-...1?part_type=10
You'll have to plug in the the hose end diameters, overall length & zero branches on the last bullet heading & then view the listings, hopefully at least some possibilities will come up.
Great lookup for hoses when doing a conversion.
1969 Camaro SSRS
Simon
The Following 2 Users Say Thank You to F'in mine For This Useful Post:
69hugger (04-11-2019), dhutton (04-10-2019)
