Old 05-17-2019, 07:04 AM
UMI Performance UMI Performance is offline
Default UMI Launches The Power Tour Package Suspension System!
We are proud to introduce our Power Tour Package. This kit includes everything you need to go from tired and frustrated after five miles to happy and refreshed after a full day on tour. We start with caster corrected tubular a-arms and poly bushing trailing arms. This solid foundation allows the suspension to move the way it should and never the way it shouldn't. The suspension is controlled with touring rate springs and improved rebound control, gas charged monotube shocks. Sway and body roll is eliminated with increased rate sway bars that hold the car flat while cornering without being too harsh. Rear frame braces and all necessary hardware round out this Made In Philipsburg, PA - USA kit.
Look for UMI's 1965 Cutlass on the 2019 Hot Rod Power Tour. We will be long hauling from the factory in Philipsburg, PA to the start, completing the entire tour, then driving home. We'll enjoy modern feel and handling while cruising in style. Oh, and if we happen to find a back road along the way, heads will turn when that ol' Cutlass is keeping up...
1964-1967 A-Body
1968-1972 A-Body
1978-1988 G-Body
The Following User Says Thank You to UMI Performance For This Useful Post:
WILWAXU (05-18-2019)
