Old 06-07-2019, 07:20 AM
Gmachine1911's Avatar
Gmachine1911 Gmachine1911 is offline
Default 68 Camaro Center Console Dimensions
I've searched the archives both here and elsewhere but can't seem to find a dimension for how tall a factory (no gauge cluster) center console is for a 68 Camaro. I'm hoping someone wouldn't mind measuring theirs. I'd love to know the how tall it is at the front as well as the distance between the front edge and the center of the manual shifter opening. Just trying to see if I have enough room with my raised trans tunnel. Thanks in advance!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
Old 06-07-2019, 09:14 PM
RdHuggr68 RdHuggr68 is offline
Is there a difference between the non gauge to the gauged console in height? I have my gauged console in the basement for my 68. If it is the same I could measure it in the morning.
Old 06-08-2019, 12:20 AM
That'd be most appreciated! I meant that I was looking for the measurement for the height of just the console itself, not including to the top of the gauge cluster. Thanks!
Shane
#theanchorholds
Old 09-02-2019, 07:01 AM
Did you get the measurements you need?
Old 09-02-2019, 12:16 PM
ADY's Avatar
ADY ADY is offline
yeah, confirm if you still need the measurements. I have the speedtech raised tunnel (http://www.speedtechperformance.com/...rod/prd264.htm with a factory center console (no gauges) and have ~.75" between the top of the tunnel and chrome shifter opening.
-Adam
1968 Camaro SS
Old 09-02-2019, 09:43 PM
Thanks guys! I did get a response but I'd love to see some pics of the console with the Speedtech setup! After doing 4 stops on Power Tour plus a few other longer road trips, I've changed my mind about not running a console. Based on the measurements I got, I don't think I can run a factory setup which is bit disappointing given the mostly stock nature of my interior. If I remember right, I've got about 4.75" of clearance from the top of my tunnel to the bottom of the dash...
Shane
#theanchorholds
Old 09-03-2019, 03:04 PM
ADY's Avatar
ADY ADY is offline
Sent you a PM to pass along pictures.
-Adam
1968 Camaro SS
