Old 06-20-2019, 02:34 PM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default Eckold KF170 Kraftformer at Trick-Tools.com
The Eckold KF170PD Kraftformer packs a lot of power for a small portable unit. It can shrink, stretch, punch, notch, clinch, planish, and has doming dies available. The sturdy base allows for a comfortable work height while still being easily moved across the shop. Quickly change the air powered machine from single to multi-stroke with the flip of a switch. The KF170PD features a 6.7 inch throat depth, 5.75 inch throat height, and a 14 gauge (2.0mm) mild steel capacity (based on tooling).
Tooling not included.
•Throat Height (inches): 5.7
•Throat Depth (inches): 6.7
•Steel Capacity: 14 gauge (2.0mm)
•Aluminum Capacity (inches): .079 (2.0mm)
•Stainless Capacity: 16 gauge (1.5mm)
•Strokes per Minute: 150 - 250
•Weight (pounds): 333
•Dimensions (LxWxH): 31 x 20 x 61
Includes:
KF 170 PD
Stand
Tooling sold separately
Click this link to see available tooling:
https://www.trick-tools.com/KF170PD-...ftformer-12900
Trick-Tools.com
[email protected]
1.877.VAN.SANT
Brycen Smith
[SIGPIC][/SIGPIC]
