Old 06-20-2019, 06:03 PM
Default Coil over trouble JRS suspension.
Front suspend = JRS apex C6 based suspension.
Qa1 Coliovers:
When i take the weight off the wheel and allow the suspension to hang he upper arm hits the spring unless I screw the lower spring adjuster on the coil-over almost all the way up which make the ride height too high.
if I try to lower the spring adjuster down, to get the right hight down.. the spring will unseat less then half of the way down the adjustment, it will sit once i put weight on it but that seems wrong..
I wouldn't be shocked to hear I need different springs.. smaller diameter or fee length.
Thoughts appreciated..
Old 06-21-2019, 11:56 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
That's a common issue with the C5/6 based subframes like AME, JRS, etc.
I let mine unload when jacking it up, and don't worry about it since it never fully unloads on the street or track, thanks to the sway bar. On Ron Myers' Camaro we used "helper," or "keeper"springs to make sure the coil springs wouldn't unseat at full droop.
Matt
http://bestofshowcoachworks.com
(760)480.0227
1969 Camaro - always broken GM Design winner
1965 Mustang - widebody fastback
2006 Coyote swapped "Rental Car"
Up next:
Steve's GT40
The Following User Says Thank You to Matt@BOS For This Useful Post:
XLexusTech (06-21-2019)
Old 06-21-2019, 05:45 PM
Matt
Thank you! any links to helper springs so I can see what you mean?
These ? https://raceland.com/news/springs-10...er-spring.html . ?
Old 06-21-2019, 06:08 PM
Matt@BOS's Avatar
yes, however, I prefer either the Hypercoil or Eibach helper springs, they have thinner, flatter coils, and have less compressed height. I also used the Eibach spring couplers because they're lower profile than the others I've found.
https://www.speedwaymotors.com/Eibac...0aAtvmEALw_wcB
https://www.speedwaymotors.com/Eibac...EaAuTYEALw_wcB
(760)480.0227
Up next:
Steve's GT40
Old 06-21-2019, 06:50 PM
dhutton dhutton is offline
I also used those Eibach helper springs on my first Art Morrison subframe. Haven’t needed them on my latest one. It still has Corvette arms but the springs are a higher rate, 550 if I remember right.
Don
Old 06-21-2019, 09:35 PM
craig510's Avatar
craig510 craig510 is offline
I like these ones:
http://https://pitstopusa.com/i-23900345-fox-nylon-spring-divider-2-5-spring-short.html
https://pitstopusa.com/i-5077505-hyp...i-d-25-lb.html
They nylon slider is glass filled and the shoulder keeps the helper from fully bottoming out. (it is the short one in the picture) Nylon will not mare up the coilover body like the aluminum ones can. The spring is light enough to compress with one hand while changing springs.
