Old 06-22-2019, 02:20 PM
Nonhog Nonhog is offline
Default Spal fans too loud!
I have a V8 Volvo (not as cool as Hackster's)
I went with twin Spal straight blade fans. Sounds like a Jet taking off when they come on. I plan to get a controller which should help but at full force it'll still be too loud. Think switching to curved blade Spal will do the trick or should I consider a different brand or a OEM single?
help a lurker out
Wife has a V8 Volvo
Old 06-23-2019, 04:52 AM
im4u2nvss im4u2nvss is offline
I used a factory 90s volvo two speed fan and relay setup. I have not had the second speed turn on yet but low is not very loud. It pulls a lot of air and cools quickly.
The Following User Says Thank You to im4u2nvss For This Useful Post:
Nonhog (06-28-2019)
Old 06-28-2019, 11:35 AM
Z06vette's Avatar
Z06vette Z06vette is offline
If you are going to get a controller, look into a variable speed setup. Runs fans at lower speeds and ramps up only as needed. Any fans that moves some air are going to have some noise at full speed. Just my experience.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
The Following User Says Thank You to Z06vette For This Useful Post:
Nonhog (06-28-2019)
Old 06-29-2019, 09:54 AM
Maybe its unfair to compare but they are way louder than any of the daily driver (OEM) fans. We are running a very mild 2000 Ford 5.0. Can't hear the exhaust when the fan kicks on.
Wife has a V8 Volvo
Old 06-29-2019, 01:42 PM
dhutton dhutton is offline
These PWM controllers help reduce fan noise considerably.
http://www.dccontrol.com/constant_te...ontrollers.htm
Don
The Following User Says Thank You to dhutton For This Useful Post:
Nonhog (06-30-2019)
Old 10-05-2019, 08:51 AM
pannetron's Avatar
pannetron pannetron is offline
The curved blade Spal fans are much quieter than their straight blade fans.
The Following User Says Thank You to pannetron For This Useful Post:
Nonhog (10-05-2019)
Old 10-05-2019, 01:09 PM
Don
I ordered (and have) that controller! I may just try the controller first.
Easy enough to swap fans if need be.
Might be taking the car in to Chris Holstrom Concepts for a non related matter.
Maybe I'll see about them wiring in the controller. (I hate wiring!)
Thanks!
Wife has a V8 Volvo
