Old 07-14-2019, 11:25 AM
g356gear's Avatar
g356gear g356gear is offline
Default Very high pedal effort on Willwood’s
I had the car out for the first time today since last fall, and the pedal effort is super high to get the brakes to engage. I have a stock dual master and power brakes. Does this sound like something a brake bleed might cure? There was no issue when it was parked. Thanks!
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 07-14-2019, 02:23 PM
g356gear's Avatar
I just double checked everything and it looks like the plastic grommet at the master cylinder had cracked with age and heat. They would explain my lack of vacuum. Thanks
The Following User Says Thank You to g356gear For This Useful Post:
camcojb (07-14-2019)
Old 07-14-2019, 06:51 PM
Track Junky's Avatar
MC piston bore would make a difference also. Smaller the piston bore size the more clamping force
Gaetano Cosentino
