Old 07-14-2019, 11:31 AM
g356gear's Avatar
g356gear g356gear is offline
Default Delayed and no shifting in turbo 400
Took the car out for the first time since last fall, and the car is having some shifting issues. If I start in 1st, and shift to second, it will not upshift. If I then shift to 3rd, it jumps past second into 3rd. If I start in drive, it seems to stay in first for a delayed period until higher speed and then jumps up. There are no leaks and it was shifting perfectly when it was parked. Fluid levels are perfect when hot....and is about 2 years old....maybe 250 miles on this trans fluid. Any ideas? Thanks!
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 07-14-2019, 12:27 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
Do you have good vacuum to the modulator?
Old 07-14-2019, 09:48 PM
g356gear's Avatar
I was having another issue with no brake boost at the same time. That issue was a cracked inlet of the line from the booster to the manifold. That is fixed, and the brake boost is back. Could that issue also affect transmission shifting?
