Old 07-24-2019, 06:24 AM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default ProLine Cast Planishing Hammers @ Trick-Tools.com
The ProLine Pneumatic Planishing Hammers are floor standing industrial quality units, based on the classic Chicago Pneumatic design, used for forming or planishing compound curves in sheet metal. They have seen use in many industries, including automobile and aircraft restoration, race car fabrication, sheet metal stamping shops, artistic applications, etc. A ProLine planishing hammer takes the work out of metal work and saves the experienced metal worker hours of time, leading to increased production.
One huge advantage in the design of the ProLine hammers is the foot pedal activation. By pressing the foot pedal down once the material is in place, you bring the dies together and start the air motor in one step. This not only allows for easy removal of your part when open, but gives very precise control of the pressure. This is not possible with most planishing hammers that have a fixed die gap. The lower arm on these cast iron floor models can be lowered to accommodate an optional bottom anvil holder for deeper parts. They feature heavy duty purpose built pneumatic motors and sturdy cast iron frames. A needle valve allows for fine tuning of power output and an automatic air cutoff switch shuts off air to the motor when the foot pedal is up. (Shown with optional die rack)
These hammers are completely fabricated in the USA. If you are looking for uncompromising quality, then you have found it with ProLine, the finest planishing hammers on the market today.
1 year manufacturer's warranty
SPECS:
•Throat Depth (inches): 24" or 36"
•Air Pressure: 80 - 120 psi
INCLUDES:
24" or 36" cast iron planishing hammer
Upper die
3R, 12R and 36R lower dies
Die extraction wrench
Dead blow mallet
Air tool oil and applicator bottle
User manual
https://www.trick-tools.com/ProLine-...g-Hammer-11539
https://www.trick-tools.com/ProLine-...g-Hammer-11538
Trick-Tools.com
[email protected]
1.877.VAN.SANT
Brycen Smith
[SIGPIC][/SIGPIC]
