Old 07-27-2019, 05:57 AM
69lsvert 69lsvert is offline
Default Alignment specs
Need alignment specs for 69 camaro. Stock subframe, tubular control arms and Viking coilovers. I need camber caster and toe for daily driver. Rear if needed is torque arm.
Old 07-27-2019, 01:38 PM
Tinker's Avatar
Tinker Tinker is offline
What brand control arms? The specs can often be found on the manufacturer's website
Chris
Old 07-27-2019, 04:23 PM
ilikeike's Avatar
ilikeike ilikeike is offline
Take a look at this.
It has some daily driver specs, as well as factory and track specs. http://www.speedtechperformance.com/...ment_Specs.pdf
The Following User Says Thank You to ilikeike For This Useful Post:
CCS (08-06-2019)
Old 07-30-2019, 03:44 PM
David Pozzi's Avatar
My Specs: http://www.pozziracing.com/first_gen...gnment%20specs
http://www.PozziRacing.com
The Following User Says Thank You to David Pozzi For This Useful Post:
CCS (08-06-2019)
