Old 07-31-2019, 05:22 AM
Schroeder Schroeder is offline
Default 2013 - 2019 Porsche 911 GT3 mirrors on a 2nd gen? Need reference measurements
I'm looking to put some larger, more functional mirrors on my second gen build. The 2013 through current Porsche 911 GT3 mirrors look great! Their shape is somewhat bullet-like and similar to the stock mirrors. Does anyone have a 911 or Porsche with gt3 mirrors by chance that they could check the shown angles on? See the pictures attached. I need to know the relation between the mirror and the mounting surface to the door. I also need to know the angle between the bottom of the actual mirror house and the neck. If this is within a couple degrees from a stock second gen mirror I should be able to work them and make them work on the build. If it's too far off some sort of spacer similar to what is on the stock cars between the door skin and the base of the mirror may have to be made. It would be thinner on one side than the other if the angles are off too much, and that might look odd.
