Old 08-16-2019, 08:36 PM
Jr's Avatar
Jr Jr is offline
Default Auto-x with wheel spacers?
Hello everyone,
What’s the general consensus about auto crossing with wheel spacers? I would like to hear your opinions.
Thank you
Old 08-16-2019, 11:32 PM
craig510's Avatar
craig510 craig510 is offline
Not a problem if they are good quality. I like hub centric but lug centric is probably fine.
Old 08-17-2019, 08:01 AM
carbuff's Avatar
carbuff carbuff is offline
How thick? I have run up to 3/8" on my car. I have longer studs to ensure good lug engagement.
If you are talking about 1" or thicker spacers/adapters to run a wheel with a lot of backspace, then I have not done that.
Old 08-17-2019, 09:21 AM
SSLance's Avatar
SSLance SSLance is offline
Agree with the above... If done right in most cases shouldn't be a problem. I've run up to a 3/8s spacer at times as well. Much prefer the proper spec'd wheel in a perfect world but we all know perfect is hard to obtain a lot of the time.
Lance
Old 08-17-2019, 11:11 AM
Jr's Avatar
Jr Jr is offline
Yes, 1” spacers with their own studs. I screwed up measuring my wheels and...
Old 08-17-2019, 04:38 PM
silvermonte silvermonte is offline
Im not a big fan on it. That being said Ive autocrossed my s10 hard all summer long with 2" wide spacers with faulken tires and have had zero issues. Mine are the type that the spacers are bolted on and then the wheels are bolted to the spacer.
Miles Boyer
96 Corvette
91 V8 S10
88 Olds Cutlass
Old 08-17-2019, 07:49 PM
Jr's Avatar
Jr Jr is offline
Silvermonte,
I have the same spacers, but mine ar 1” thick.
Are you running them on the front and rear?
Old 11-05-2019, 07:11 AM
SoloTech SoloTech is offline
Rule #1 - Always have adequate thread engagement of the wheel studs.
Old 11-05-2019, 07:16 AM
If the spacer is thick enough that your wheel will no longer pilot on the hub, hub centric/wheel centric spacers are recommended.
Old 11-06-2019, 12:54 PM
UMI Tech's Avatar
UMI Tech UMI Tech is offline
As mentioned above, wheel spacers within reason while not ideal don't seem to pose a problem. We use a few of them here at UMI but always with ARP studs, properly torqued and maintained.
The Following 2 Users Say Thank You to UMI Tech For This Useful Post:
BMR Sales (11-07-2019), Marshchevelle (01-31-2021)
