Old 08-22-2019, 11:23 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Default G-Body Wheel Hubs
I have a set of 2016 Camaro SS (5x120mm) wheels that I'd like to run on my 78 Malibu (5x4.75). I'm running a Belltech S10 lowering spindle (#2102) on the front and a Grand National 8.5 10 bolt in the rear. I would guess I can order new axles for the rear with the 5x120mm bolt pattern but I am stuck on the front. I can't find a bolt on hub that will work. Can anyone steer me in the right direction or offer any suggestions.
Jose
Old 08-23-2019, 04:08 AM
At the risk of sounding dumb did you try Camaro hubs?
Old 08-23-2019, 09:23 AM
CRCRFT78's Avatar
I did look at using the 2016 Camaro hub. The measurements between the two hubs are different so before I go out and buy one for a test fit I thought I'd ask first.
Jose
