Old 08-27-2019, 02:34 PM
Craig69 Craig69 is offline
Default Radiant heat
Anyone ever wrap headers and pipes on a turbo car and radiant heat get worse?
Old 09-01-2019, 06:25 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
Craig69,
I may have a theory on why radiant heat was elevated but before we go there..,
1. How thick is your wrap? 50% overlap?
2. Do you possess an infrared temp gun?
3. How are you measuring radiant heat?
(As a nuclear engineer, I have to address thermal insulation on a larger scale..,but please know this.., if you study heat transfer,
there is a point of insulation thickness where it actually increases radiant heat because of increased surface area to radiate with inadequate insulation factor.)
Sorry nobody has replied yet.
Please reply.
I wanna help
572Camaro
Old 09-01-2019, 07:16 AM
Build-It-Break-it's Avatar
When I use to drag race imports I used thermal wrap and it cracked 4 different turbo manifolds. I tried stainless manifolds and mild steel, all wrapped using different overlap techniques and same results, they all cracked. I never used wrap again .
What I did that worked was hood venting. The difference wasn't dramatic but it was effective.
Ahmad B
