Old 09-12-2019, 08:55 AM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
Default Battery Cable Route
I would like to know what the group thinks is the best way to run the main cable. I keep going back and forth on the under vs inside. Please provide your ideals and pictures if you have any. Thanks in advance.
Old 09-12-2019, 09:46 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
In side it will be better protected, but you'll need a grommet or bulkhead to go through the body. I'm running mine inside the car personally. That's how GM does it on new cars with the trunk mounted batteries.
Instagram- camaroaj
The Following User Says Thank You to CamaroAJ For This Useful Post:
Bakaruda (09-12-2019)
Old 09-12-2019, 04:05 PM
slimjim's Avatar
slimjim slimjim is offline
+1 for inside, for mine I placed the battery on the passenger side in the rear, ran the 1/0 along the passenger Side of the transmission and passed it through a grommet close to the starter. charge wire runs through a seperate grommet from alternator back to the battery via the drivers side of the tunnel.
NC
streamline 68 camaro
Build Thread here
The Following User Says Thank You to slimjim For This Useful Post:
Old 09-12-2019, 05:04 PM
ADY's Avatar
ADY ADY is offline
Curious, what's the thinking behind running a separate charge wire from the alternator to the battery?
-Adam
1968 Camaro SS
Old 09-12-2019, 05:12 PM
eville's Avatar
eville eville is offline
It’s usually done only when a solenoid is placed in the trunk to make the battery to started lead hot only during cranking.
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
The Following User Says Thank You to eville For This Useful Post:
ADY (09-12-2019)
Old 09-12-2019, 05:32 PM
Bakaruda's Avatar
I appreciate the replies. I have always ran it under the car. I may go the inside route this time.
Old 09-12-2019, 08:33 PM
Gmachine1911's Avatar
Gmachine1911 Gmachine1911 is offline
I ran mine inside as well using a bulk head to pass thru into the engine compartment. On a First Gen there's a nice little ledge that seems perfect for running the cables and bulkhead. I admittedly stole the idea for mine from pics on DSE's project updates page!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
The Following 3 Users Say Thank You to Gmachine1911 For This Useful Post:
Bakaruda (09-13-2019), dhutton (09-13-2019), kmart401 (10-01-2019)
Old 09-13-2019, 07:00 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
Agree with all above
I ran my 1/0 “navy strand” cables inside under carpeting along outer edge on passenger side and grommeted firewall at starter location.
Curious if you are running fuel injection?
If you are, try to keep your EMF sensitive fuel injection wiring to the battery separated from other wiring.
Old 09-13-2019, 07:43 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
I'd go inside.
You can hit the "you pull-it" junk yard and grab the LX cars' battery bulkhead connector in the passenger footwell. Super nice, high current, OE quality piece. If your feeling extra energetic, pull out the cable while your at it. It's a high quality cable and ends you can get for next to nothing.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 09-13-2019, 08:43 AM
eville's Avatar
Originally Posted by CJD Automotive View Post
I'd go inside.
Which LX cars?
Steve
Check it out Here
Spiffav8 (09-24-2019)
