Old 09-12-2019, 11:44 AM
rickpaw rickpaw is offline
Default 67 Firebird 400 - LS2/TR6060 Ridetech
Item Location (City/State): Houston, Tx
Price: $43,500
Description:
I'm testing the market to see if I can sell the Firebird and move on something different.
The car is a true 400/400 Firebird, with deluxe interior. Original motor/tranny were long gone when I acquired it. Did a frame off restoration on it in 2009/2010.
Body:
-Quarters/trunk pan replaced. Patch panel on the rear driver floor board.
-Frame off restoration with new or refinished hardware.
-Subframe connectors/DSE 4 point roll cage.
-Fiberglass Trans Am hood
Mechanical:
-LS2/TR6060 swap. LS2 has about 1k since rebuilt and has a small Cam Motion cam, upgraded to bronze rocker bushing, new oil pump/timing chain/front/rear seals. 243 heads rebuilt with PaC springs/titanium retainers.
-TR6060 is stock 80k drop out from a 5th gen and new (less than 1k miles) LS7 clutch/flywheel, and new GM slave. MGW shifter with adapters to mount the shifter directly to the tail housing (got rid of the stock remote shifter)
-58x with LS3 throttle body.
-McCleod manual conversion with wilwood m/c.
-Holley Dominator EFI set up.
Interior:
-Mostly stock with Recaro Specialist seats, recovered stock rear bench.
-VHX gauges with GPS module. Speedhuts gauges for oil temp/fuel pressure.
-5th gen console
-Vintage Air AC
-6 speaker stereo, with subwoofer/Alpine amps
-New AAW wiring harness. LED tail lights/halogen headlights running thru relays.
-Front 3-point Morris seatbelts, stock lap belts rear
Suspension:
-SPC front upper/lower control arms.
-Ridetech 4-link rear.
-Ridetech single adjustable coil overs front/rear.
-Speetech AFX tall spindle
Wheels/Brakes:
-Front: Wiwood Aero6 calipers with C6 Z51 DBA rotors
-Rear: stock 4th gen rear discs with working parking brakes.
-Wiwood 1" mc with 9" dual diaphram booster
-Formula 43 3-piece wheels: 18x8.5 front/ 18x9 rear. 245/45/18 tires front; 275/35/18 rears
Car is a driver, with paint chips here and there. It's been on PowerTours; Cruisin the Coast, and participated in Optima challenge and LS Fest.
Clear title in my name.
IMG_1477 by Tu Ho, on Flickr
IMG_1476 by Tu Ho, on Flickr
58984850590__FA95E872-4CBC-47C8-8F59-71FE4B1B3210 by Tu Ho, on Flickr
IMG_1479 by Tu Ho, on Flickr
Tu Ho
Old 09-21-2019, 03:27 PM
Ttt.
Reasonable offer accepted
Tu Ho
Old 09-22-2019, 08:26 AM
Sad to see this for sale but know someone is getting a good deal on it. Good luck with the sale and excited to see what is next.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 09-25-2019, 08:44 PM
Thanks Will.
Tu Ho
