Old 10-14-2019, 08:39 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Default Cerakote
Guys, is cerakoting just as durable as powdercoating? I've heard mixed reviews. Specifically, I'm concerned with cerakoting wheels.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 10-14-2019, 12:14 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Hard to say for sure. Cerakote is very durable and once fully cured (48hrs if I recall correctly) it is very scratch resistant. Its also a lot thinner than powder coat. Two light coats is about all we put down over sandblasted bare metal. Overall we've been happy with everything we've Cerakoted, which mostly trim parts, suspension components, etc.
On a set of wheels, I think Cerakote would be just as durable!
Matt
http://bestofshowcoachworks.com
(760)480.0227
1969 Camaro - always broken GM Design winner
1965 Mustang - widebody fastback
2006 Coyote swapped "Rental Car"
Up next:
Steve's GT40
Old 10-14-2019, 12:21 PM
anguilla1980's Avatar
anguilla1980 anguilla1980 is offline
As a gun guy, we have had cerakote for a very long time on all types of gun parts, slide most notably. It seems car guys are just discovering it starting about 5 years ago.
It will be fantastic for wheels.
Keep in mind, it will scratch if you really try. If used on surfaces that see lots of rubbing, it will wear off, but over many cycles. It doesn't really fade in the sun. I'm partial to keeping it looking new with a nice thin coat of gun oil then wiping that off, haha! I've seen in the automotive space tho some places doing a glossy finish on it.
https://www.TheFoat.com/92GTA
1969 Pontiac Firebird w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
Old 10-14-2019, 01:40 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Hellfire has the trim and I think the wheels coated in it.
Instagram- camaroaj
Old 10-14-2019, 02:29 PM
Stielow's Avatar
Stielow Stielow is offline
Yes Hellfire has wheels, window trim, outside door handles, window cranks, inside door handles and locks all coated. The thin coating worked great on all the parts.
After a lot of abuse the coating seem fine except for the exterior door handle coating seems to be wearing off.
Nice stuff.
Mark
Old 10-14-2019, 03:12 PM
214Chevy's Avatar
Thanks guys!! I appreciate the advice. I'd assume the only rubbing that the wheels would see would be from normal washing and wiping to keep clean. I wonder how long that would last?
'68 C10 swb
'72 Chevelle
Old 10-27-2019, 09:52 PM
Jr's Avatar
Jr Jr is offline
Has anyone cerakote their exhaust?
Old 10-28-2019, 06:55 AM
clill's Avatar
clill clill is offline
That coating is awesome on Hellfire's wheels. The coating hides the dirt. I pretty much just rinse them off and call it good. I also use a Lucas tire dressing in a spray bottle that when sprayed on the rims makes them look fresh.
The Following User Says Thank You to clill For This Useful Post:
214Chevy (10-28-2019)
Old 10-28-2019, 07:39 AM
214Chevy's Avatar
Thanks Charlie...
'68 C10 swb
'72 Chevelle
