Old 02-27-2020, 11:16 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default Autometer Temperature Gauge with Classic Instruments SN12MM Sending Unit??
My temperature sending unit was initially installed on the upper radiator hose. However, I wanted a cleaner look, and ordered the classic instruments sending Unit SN12MM to fit on the passenger side head.
Now I am replacing my old classic instruments gauges with autometer gauges kit.
Automer temperature gauge comes with sending unit.
Just wondering can I use the autometer gauge with my existing classic instruments temperature sending unit or I have to use the autometer sending unit instead.
Will appreciate your input guys.
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
