Old 03-14-2020, 06:56 AM
vstol vstol is offline
Default New 12 bolt pinion seal leaks
While I was replacing the transmission and drive shaft I thought I would replace my rear pinion seal on my 12 bolt in my 72 Camaro. Well it leaks more now than when I replaced it, I will replace it again but what I'm I missing? It has been on the lift since I replaced it and it has not been out on the road does it need some road time to seal better??
Old 03-14-2020, 07:05 AM
I found this can anyone verify this
https://www.bing.com/videos/search?q...74E7&FORM=VIRE
Old 03-15-2020, 07:14 AM
On another forum they said to use the Raytech seal, anyone use those?
Old 03-15-2020, 06:19 PM
Che70velle's Avatar
Seems right. I’ve put 3 new pinion seals in my 12 bolt...they all 3 leak. I am going to do a gear change soon, and I’ll try the spacer mod.
Thanks for posting this!
Thanks Dad!!
Old 03-15-2020, 06:25 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
https://r.tapatalk.com/shareLink/top...ink_source=app
Hope that link works. I find Freddie (big gear head) is always right. He built rears for a living in his shop for like 40 years
Scott from NJ
Old 03-16-2020, 07:49 AM
68454RS's Avatar
68454RS 68454RS is offline
Ratech Pinion Seals 6109, Got mine from Summit racing https://www.summitracing.com/parts/RAT-6109
68454RS's Avatar
Yes and it worked perfect
Old 03-16-2020, 01:55 PM
Che70velle's Avatar
Well then...I’ll try the Ratech seal instead of the spacer mod.
Thanks Dad!!
Old 06-23-2020, 04:48 PM
Jimbo1367 Jimbo1367 is offline
Great find. Thanks to all that have added to this thread. This should be a STICKY
Jim
Old 08-03-2020, 04:59 AM
71 RAT's Avatar
71 RAT 71 RAT is offline
I 2nd spacing the seal. I rebuild driveline for a living, this has been a problem for some time. I machined a spacer for my car years ago. Customers, I use C4 C6 square cut servo seal to space the away for the bearing.
71 SS 454 TH400 2.74 1st gear GV Overdrive 3.55 Gear SC&C Stage 11 QA1's 4 Wheel Baer Brakes AGR Box Straub SR .630 .612 lift 240 256 [email protected]
83 K20 454 TH475 NP 205 Dana 60 Track Lok Detroit Locker Rear
58 Ford 821 Powermaster Loader Backhoe Restored Family Heirloom
