Old 04-03-2020, 02:10 PM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default Hole Saw Transfer Punch kit / Trick-Tools.com
The Hole Saw Transfer Punch was designed by Tucci Hot Rods to help find the perfect center for a hole or radius when larger than a standard transfer punch kit size. Simply find a common hole saw that matches the hole or radius that you are working with and insert the proper arbor (included). Slide in the hardened punch and tap with a hammer just like a typical transfer punch. Perfect for duplicating sheet metal panels.
The threaded arbors are Zirconium Nitride coated to make sure they never wear out. The kit comes with a 3D printed tool holder with magnetic base to keep organized and close at hand.
https://www.trick-tools.com/Tucci-Ho...unch-Kit-13688
Trick-Tools.com
[email protected]
1.877.VAN.SANT
Brycen Smith
[SIGPIC][/SIGPIC]
