Old 09-05-2006, 03:30 PM
MaxHarvard's Avatar
Default T56 wiring diagram?
Does anyone have one?
Old 09-05-2006, 03:44 PM
chicane's Avatar
chicane chicane is offline
What exactly are you looking for ?? Sensor, skip shift.... speedo stuff ??
Here is a linky to the factory service manual, but it doesnt really show electrical representations that I think you are after..... but it is something good to have around.
Street and Performance has a diagram on their web site but I can not get it to open.
file:///C:/spwebsite/Street&performance%20folder/Street&performance/ONLINETECH/T56WIRINGallebook.pdf
Old 09-06-2006, 12:57 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
If you buy the OEM GM connectors, the connections are as follows:
Reverse Lockout
Pink - +12V
Green - ground
Backup Lights
Green to ignition +12V
Brown to backup lights
VSS
Purple – speedometer signal
Green/Black - Ground
