Old 05-26-2020, 09:17 AM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default Pro-Tools MB-105HD Tubing Bender Overview | Trick-Tools.com
This hydraulic bender kit combines the ever-popular MB-105HD tubing bender with a hydraulic upgrade of your choice along with a rolling stand. This kit is perfect for those that don't wish to permanently take up shop space by bolting down a manual bender but are still looking for an economical solution that produces fantastic results.
With 2 inch OD x .188 wall (1-1/2 inch pipe schedule 40) bending capacity, the Pro-Tools Model 105HD bender is a great choice for building rock-crawlers, buggies, motorcycle frames, handrails, and many other projects. Other features include steel bushings at the main die pivot to reduce friction and ease die change-out, included degree plate for a degree of bend reference. An optional stop kit that allows for repeatable bends is also available. Choose from the foot pedal actuated air powered hydraulic pump which uses your shop's compressed air, or our 110v electric hydraulic pump with hand pendant remote for ultimate speed and mobility.
The large selection of available die sets for round and square tubing, nominal pipe sizes (NPS), and metric tubing, make this machine extremely versatile (see accessories tab). Custom sizes and radii can be quoted upon request.
Electric/hydraulic pump kit requires 3 quarts of ISO 46 hydraulic fluid
Die sets are sold separately
Warranty:
1-year manufacturer's warranty
SPECS:
•Mild Steel Capacity (inches): 2 x .188
•Round Dom Capacity (inches): 2 x .134
•Nominal PIPE Capacity: 1-1/2 inch schedule 40
•Square Mild Steel Capacity (inches): 1-1/2 x .083
•Solid Bar Mild Steel Capacity (inches): 1-1/8
•Minimum OD (inches): 1/2
•Bending Style: rotary draw
•Min Center Line Radius (inches): 2
•Max Center Line Radius (inches): 7
•Max Degree of Bend: 180
•Maximum OD (inches): 2
•Weight (pounds): 140
INCLUDES:
MB-105HD/TT
Hydraulic conversion package
Rolling pedestal
Degree plate
Pins - center, drive, counter die, and u-strap
Bending lube sample
Die sets sold separately (see accessories tab on trick-tools.com)
Trick-Tools.com
[email protected]
1.877.VAN.SANT
Brycen Smith
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Trick-Tools.com For This Useful Post:
camcojb (05-26-2020)
