Old 06-02-2020, 04:27 PM
Default Dot 5.1
Looking at the pros and cons, I quickly eliminated Dot 5 .
THe proice of 5.1 is basically the same as DOT 3/4 with higher biouling point (270 degrees).
So given a bran new brake system with OEM (Detroit speed master) and OEM KORE3 C6 Brake calipers.. I was leaning toward DOT 5.1
Any downside to this decision?
Can it be used for clutch fluid ?
PS the latest thread i found was from 2016 so I did search..
Old 06-02-2020, 05:46 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Interested in this also....
Old 06-02-2020, 09:21 PM
randy randy is offline
Unless you are. Easy racing your car your brake fluid temp will be fine with dot 3 or 4. Remember the rest of your brake system has to withstand those temps. I doubt you will run your car to the extreme and have on racing brake pads. I went with dot 5 which is different than dot 5.1 in the beginning. I’m not running dot 3 or 4. Reg cheap stuff
Old 06-03-2020, 05:32 AM
dontlifttoshift's Avatar
Everything here in the shop gets DOT 4. The cost difference between 3 and 4 is negligible.
Anything that will see track time gets 5.1 It's cheap insurance. You do not need race pads to boil brake fluid.
Donny
Old 06-11-2020, 09:19 AM
anguilla1980's Avatar
anguilla1980 anguilla1980 is offline
I've had great luck with Redline RL600 DOT 4, it has a 600F boiling temp.
If Redline made a 5.1 I might switch to that.
https://www.TheFoat.com/92GTA
1969 Pontiac Firebird w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
Old 06-11-2020, 06:21 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Dot 5.1
Used to run dot 5.1 in my motorcycles all the time
Switched to a dot 5 high temp in my pantera and it was swelling my
Seals. Found out after it locked up my brakes the second time
Now using Dot 4 Fliud per the brake master cylinder rebuilder
Make sure your seals can take 5 or 5.1 fluid
Bob
