Old 07-13-2020, 05:45 PM
spazegun2213 spazegun2213 is offline
Default 2010+ Camaro pump with fuel level?
Is anyone running a 2010+ Camaro fuel pump AND using the level sensor? if so, how are you doing it? It looks like the E38 ECM *can* handle the inputs, but every wiring diagram I see for the Gen5 camaro shows it being piped through the fuel control module then to the ECM.
Old 07-19-2020, 04:42 AM
CapSS92 CapSS92 is offline
Hook it up into the connector J1 pins #16 and #31. That should give you a fuel reading.
Alex
