Old 09-08-2020, 01:07 PM
anguilla1980's Avatar
anguilla1980 anguilla1980 is offline
Default Brake duct kit?
Are there any vendors who make full front brake ducting kits for 1st gens with Wilwood brakes? Seems like a super common setup to justify making these. I don't want cheap plastic universal ones like the Allstar stuff.
I'm running Wilwood Aero6 14" brakes and I'm looking for fully ducted backing plates. Needs to work with the Wilwoods and have the inlet where it won't interfere with the sway bar, tie rod or anything else on a 1st gen.
I can figure out the hose and the inlet ducts, going for a single 3" or 3.5" setup. I'll be coming in directly from my front lower air damn. I won't be running fans.
Any leads on where I can get the ducted backing plates for Wilwoods? Has anyone made these before and would be willing to make me a custom set?
This universal kit looks promising but no idea if that backing plate will work with a 1st gen: https://howeracing.com/products/brake-duct-kit
Thanks!
https://www.TheFoat.com/92GTA
1969 Pontiac Firebird w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
