Old 09-25-2020, 12:10 PM
nickstev512 nickstev512 is offline
Default Hawk HPS and Carbotech 1521
This is actually my first post here, after reading alot about suspension, but I have a brake pad question. I have Forged Dynalites on the front and Dynapro Low Profiles on the rear. I was planning on using Hawk HPS all around, but they don't make them for the Low Profiles. Would using HPS in the front and Carbotech 1521 be a good idea? If not, what pads should I use on the rear with the HPS?
Old 10-07-2020, 08:29 AM
bmiller's Avatar
bmiller bmiller is offline
I have the opposite setup, I have carbotech ax6’s in the front and a hawk pad in the rear. No problems after a lot of street and auto x time. As long as they handle heat, cold stops and noise level similarly I don’t think you’ll notice anything
Brandon
71 El Camino
63 Nova
70 Buick GS
