Old 11-11-2020, 08:12 AM
1Bad68Cat 1Bad68Cat is offline
Default Power Steering System
Hi Lateral-G faithful,
Not sure if this is the correct forum, if not, Admins please move. I am losing my power steering after the truck gets up to temperature or after a short drive. It only comes back after the truck has cooled down. The power steering fluid is hot which I think is the issue. A little about the truck. I have a 66 C10 with an LY6/6L90 swap. Used the donor truck's front drive accessories. I am also using an Astro Van hydroboost and a CPP steering box. I've replaced the power steering pump, the power steering lines, and the hydroboost, but see no improvement. I've also installed a 4th gen camaro power steering cooler. I'm hesitant to change the steering box only to find out that didn't work either. Any suggestions on what else I can check? If it's suggested to change the box, is there something I can check in the box that can be remedied before ultimately going that route (some kind of valve for instance)? FYI, the power steering pump has the dual return for hydroboost as the truck the engine came from had hydroboost. Thanks in advance.
Robert Icasas
Projects:
67 Cougar
Art Morrison Sport IFS
3-link Rear Suspension
Coyote w/ D&D Performance Viper t56
Build: https://lateral-g.net/forums/showthread.php4?t=50170
Brother's 1966 Mustang Restomod
Mustang II front suspension
Torque Arm Rear Suspension
Ridetech Shockwaves
5.0 w/ Viper t56
Old 11-11-2020, 02:57 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Maybe an oil cooler would help.Just put it on the low pressure side.
Old 11-11-2020, 03:18 PM
I'll give that a shot. I just didn't expect to need it for a street driven truck.
Robert Icasas
Projects:
67 Cougar
Ridetech Shockwaves
5.0 w/ Viper t56
Old 11-13-2020, 07:39 AM
I forgot, are you referring to a standard oil cooler as apposed to the gen IV camaro power steering cooler I already have installed?
Robert Icasas
Projects:
67 Cougar
Ridetech Shockwaves
5.0 w/ Viper t56
Old 11-13-2020, 10:05 AM
Zspoiler's Avatar
If the one you are already using isnt enough .Then you can always try a larger size.
Old 12-06-2020, 02:49 PM
CraigS CraigS is offline
In My FFR roadster I used to lose assist on hot days 3/4 through an autocross run. Honda PS fluid helped a lot but the final fix was a cooler in the return line.
https://www.summitracing.com/parts/der-13311
Old 12-06-2020, 06:25 PM
Musclerodz's Avatar
have you swapped positions on the return lines? Your aerating the fluid and not getting the air out before its getting pumped back into the system. If that doesn't help get a larger remote reservoir from KRC.
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-07-2020, 08:09 AM
Hi Mike. I've tried swapping return lines with no luck. My biggest concern is I'm not auto-crossing, so I'm a little surprised I even need a cooler. I'm left wondering if I'm overlooking something basic that is causing me issues. I changed the gear box this past weekend since I was able to get it covered under warranty. As soon as I have the rest of the truck back together, I'll see how the power steering behaves.
Robert Icasas
Projects:
67 Cougar
Ridetech Shockwaves
5.0 w/ Viper t56
Old 12-09-2020, 01:06 AM
CarlC CarlC is offline
Fluid temperatures can be monitored with something like this: https://www.mcmaster.com/temperature-stickers
What power steering fluid is being used? It is surprising how bad most of the name brand power steering fluids are, and how good the real GM power steering fluid is.
http:www.vaporworx.com
The Following User Says Thank You to CarlC For This Useful Post:
dhutton (12-09-2020)
Old 12-09-2020, 07:26 AM
Carl, I've used all different kinds from ATF, to "Power Steering" fluid. At the moment, I have switched out the steering box, flushed the power steering system and I'm using Lucas per the steering box manufacturer's recommendation. After I finish the remaining to-do list items on the truck, I'll take it for a test drive.
Robert Icasas
Projects:
67 Cougar
Ridetech Shockwaves
5.0 w/ Viper t56
The Following User Says Thank You to 1Bad68Cat For This Useful Post:
rellim88 (03-21-2021)
