Old 11-23-2020, 04:36 PM
Default GM IdidIT column
OMG ready to loose it after loosing so much time today.
Anyone know the thread and pitch on IdidIt column nut for the steering wheel?
I see lots of wheel tool kits have 9/16 -18 threads... before i overnight a kit wanted to ck here
ordered based on https://www.summitracing.com/parts/idt-9200041740
Old 11-24-2020, 01:12 AM
Bad Bowtie Bad Bowtie is offline
Lexus,
If your looking for just the nut here is what I've read fits.
https://www.summitracing.com/parts/i...yABEgL8XvD_BwE
BB
Old 11-30-2020, 09:33 AM
camcojb camcojb is offline
Probably too late, but mine is 9/16" fine thread.
XLexusTech (11-30-2020)
Old 11-30-2020, 04:02 PM
Default so more Info...
SO here is more info... I needed to adjust the directional lever and made the mistake of removing the C clip. NO big deal right well not so much.. the Idid it column uses a 65 lb spring to load the upper bearing. that spring is held in with the horn contact.... and a c-clip.... Ididit provides a kit with a tube.. to lock it in.. but i wasn't going for it..
TLDR.. ordered a cheap puller kit from amazon.. needed the thread pitch to make sure the tool would work.. paid 20 bucks was worth every penny..
The Following User Says Thank You to XLexusTech For This Useful Post:
camcojb (11-30-2020)
