Old 11-29-2020, 10:36 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Default Magnum F
Wondering if anyone has swapped from a T56 to the new T56 Magnum F? My big question is fit and shifter lineup comparison.
Curtis
Old 11-29-2020, 01:54 PM
I have a magnum.. how can I help
Old 11-29-2020, 03:06 PM
Spiffav8's Avatar
Lateral-g Moderator
Is it a Magnum or the new Magnum F-Body? Looking for some feed back on the swap between a T-56 and the new T-56 Magnum F-Body.
http://https://tremec-blog.com/intro...-gen-f-bodies/
Curtis
Old 11-29-2020, 03:41 PM
OH.. its a regular Magnum.. sorry.
The Following User Says Thank You to XLexusTech For This Useful Post:
Spiffav8 (11-30-2020)
Old 11-29-2020, 04:57 PM
130fe 130fe is offline
Thumbs up
Curtis, I think that F body one is a bolt in replacement for the 98-02 4th gen cars. Give those guys a close ratio version compared to the GM one. I don’t see a reason you couldn’t swap one if you already had a 4th gen one in your car. Honestly, I would just get a close ratio magnum(regular) and call it a day.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
The Following User Says Thank You to 130fe For This Useful Post:
dhutton (11-29-2020)
Old 11-30-2020, 10:42 AM
Spiffav8's Avatar
Lateral-g Moderator
I didn't raise the trans tunnel in my 67 and the current T56 fits, but it's crazy tight. No way a regular Magnum is going to fit in there. From what I've read, the Magnum-F should fit, but.... we've heard that before. Was hoping to find someone that's done the T56 to T56 Magnum-F swap and get some feedback.
I blew the seal out of the tail shaft housing on my current T56 Stage II setup. Apparently a common issue and weak spot. Not sure how much fluid was lost or how much internal damage was done. Oddly one of the AC compressor fittings broke at the same time and the fluid leaked out. Pulled over upon seeing the smoke and found the broken line. Assumed the smoke was the oil burning off the exhaust. Mopped up what I could and headed for home. Hit the freeway and about 60 MPH experienced a very aggressive vibration. Slowed down, took the next exit and pulled over. Found the rear of the car covered in transmission fluid. Limped the last two miles home super slow. No noise, or smoke at the low speed. Cleaned the car up (top to bottom) and found the issue. Not really surprised. Not thrilled, but I drive the car aggressively.... cause that's what it's for. No big. Just glad it didn't happen on the drive home from GoodGuys Scottsdale last weekend.
Appreciate the feedback!
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
WILWAXU (11-30-2020)
Old 11-30-2020, 01:07 PM
Atta boy! Keep finding the weak links.
The Following 2 Users Say Thank You to Vegas69 For This Useful Post:
130fe (11-30-2020), Spiffav8 (11-30-2020)
Old 11-30-2020, 10:11 PM
WILWAXU WILWAXU is offline
Thumbs up
Great post! I'm curious about the same question.
Hoping the Magnum-F fits same in the tunnel as a regular f-body T56. I'm using the Holley/Hooker engine/trans mounts in my Nova.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 12-01-2020, 09:46 AM
gnx7's Avatar
gnx7 gnx7 is offline
I've installed a bunch of the F style units as they have been out for about a year now. The only real thing you need to change from your standard T56 is the 31 spline yoke. Otherwise it is a bolt in and your other wiring connectors are plug/play.
I'm pushing over 1200rwhp thru a 100% stock T56 Magnum F style in my LS9 turbo RX-7 without issues (this car isn't in my sig). Runs high 8's@173mph and is a full on street car (3.31 gears in an 8.8" out back). I don't launch it hard as breaking stuff isn't my happy place. The shifting smoothness is no comparison to your older T56 and the .80 5th is great as you stay in your powerband better.... I shift at 7800rpm when doing 1/2 mile racing
The Following User Says Thank You to gnx7 For This Useful Post:
Spiffav8 (12-01-2020)
Old 12-01-2020, 05:12 PM
Spiffav8's Avatar
Lateral-g Moderator
That's a pretty good sales pitch. This goes inline with everyone else I've talked to that has any knowledge on the "F". I ordered one, along with the 31 spline yoke this morning.
Thanks for information vote that this is the right way to go.
Once the install process starts, I'll post whatever pictures I get.
Curtis
