Closed Thread
Old 12-01-2020, 11:28 AM
lzdick's Avatar
lzdick lzdick is offline
Default Detroit Speed Quadralink Rear Swaybars (2)
UPDATE:
Both swaybars have been SOLD !!!
Thanks, Lateral-G
Item Location (City/State): Barrington, IL
Price: $125 each
Description:
FOR SALE: Two used (2) Detroit Speed Quadralink rear sway bars for 1967-69 Camaro/Firebird and 1968-74 Nova. One is 1-⅛" diameter, the other is 1-¼". To be fair, 1st swaybar sold gets bushings PLUS brackets. 2nd bar sold gets bushings only; only have one set of brackets. If in need of kit hardware (that I have re-used), quite sure a call to Kyle at DSE can make that happen for you.
1-⅛" Swaybar: With bushings and brackets (no other hardware). Rated 311 lbs./in.-front hole; 364 lbs./in.-rear hole.
1-¼" Swaybar: With bushings and brackets (no other hardware). Rated 496 lbs./in.-front hole; 580 lbs./in.-rear hole.
$125 each plus shipping.
Old 12-02-2020, 06:25 AM
TPI Guy TPI Guy is offline
I’ll take the 1-1/8”
Old 12-02-2020, 07:53 AM
KAN KAN Speedshop KAN KAN Speedshop is offline
Default 1 1/4 Sway bar
I will take the 1 1/4
Old 12-07-2020, 08:06 PM
lzdick's Avatar
1-⅛" swaybar has been SOLD !!!
1-¼" swaybar is still available.
Old 12-11-2020, 12:34 PM
lzdick's Avatar
Thanks, Lateral-G
Closed Thread
