Old 01-12-2021, 05:57 PM
Default DSE coil over Kit for stock subframe
Has anyone used this front coil over kit from Detroit Speed on a first gen Camaro?
https://www.jegs.com/i/Detroit-Speed...30311/10002/-1
Any opinions or have you install them?
Thanks!
Old 01-14-2021, 11:47 AM
redfire69's Avatar
redfire69 redfire69 is offline
Hi Wayne,
I've installed them as part of the speed kit 2. Install was straight forward, hardest part was clearancing the spring pocket. It wasn't too bad since I had the front sub frame stripped down and could turn it upside down to access. See page 3 at: https://www.detroitspeed.com/img/pro...sion%20Kit.pdf
Ron
Ron
69 Camaro Redfire
The Following 3 Users Say Thank You to redfire69 For This Useful Post:
billohio (01-14-2021), Spiffav8 (01-15-2021), waynieZ (01-14-2021)
Old 01-14-2021, 11:20 PM
Hi Ron, how do you like them? I'm thinking of going with the DSE single adjustable shocks.
Thank for posting.
Wayne
Old 01-15-2021, 08:38 AM
redfire69's Avatar
Thank for posting.
Wayne
Hi Wayne,
I can't comment on their performance as I'm still in the build stage of my car, but feedback I've heard from others is good. One thing you want to check is the weld quality around the shock support to frame as I've heard of one failure of the stock sub frame.
-Ron
Ron
69 Camaro Redfire
The Following User Says Thank You to redfire69 For This Useful Post:
uk68327 (01-16-2021)
Old 01-15-2021, 08:40 PM
When MCC did my frame he welded up all the seams on the frame. But thanks for the heads up.
I'd like to find out how much it would be to get the Speed Tech chicane setup installed. If anybody had it done if you could let me know a ball park figure I'd appreciate it.
