Old 02-28-2021, 06:46 PM
tumper93 tumper93 is offline
Default cutting painted panel
Anyone have advice on how to cut on a painted panel? I am looking at installing Anvil hood vents on my painted hood. Three of the sides are hidden by the vent but the rear cut goes over top of the vent and the vent tucks under the hood there to hold it down. This edge will need to be have the paint unburnt etc. I have air saws, grinders, cutoff tools, etc just need some advice on the best way to handle this.
Old 02-28-2021, 07:52 PM
JB400's Avatar
JB400 JB400 is offline
Lay down painter's tape on your cut lines to prevent chipping.
Old 03-01-2021, 02:40 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Post pics when it’s done.
Curtis
Old 03-01-2021, 04:49 AM
dhutton dhutton is offline
Any kind of abrasive cutoff wheel will likely burn the paint. I would use a square punch something like this and make a series of punches. Or use the punch to punch the two corners and then join them with a body saw with a fine blade. Score the paint on the cut line with a sharp razor blade.
https://www.amazon.com/Q-Max-Q-Max-S.../dp/B07DVFXJJN
I just installed a set of these on a Mustang hood. It will be tricky if there is a second layer of metal brace under that area. The brace will have to be cut back beyond the straight edge by 1/4” or so.
You will need to put some kind of paint on the cut edge to prevent rust. I would use a quality epoxy primer.
One other tip would be to take the time to make an accurate template. I used some chipboard but poster board would work too.
If the basecoat was not activated it will be easy for the clear to lift. Go slow and easy and be prepared with a backup plan to repaint the hood. Not trying to scare you but you need to be realistic.
Good luck,
Don
The Following User Says Thank You to dhutton For This Useful Post:
camcojb (03-01-2021)
