03-03-2021, 08:34 AM
finish and paint bottom before bodywork?
My car is on a rotisserie and I am currently finishing the floorpan metalwork, mini tubs, and a Speedtech torque arm install.
I am curious if the process is to completely finish the metalwork on the bottom and then paint and spray Bedliner?
The rest of the car would still need quarter panel patches, trunk weatherstrip area patched, etc.
Thanks!
03-03-2021, 09:27 AM
not that im an expert in anything but i dont see a problem with it ,as long as all the rest of the panels are good ...rockers inner rockers trunk drop offs wheel wells etc
The Following User Says Thank You to raustinss For This Useful Post:
03-03-2021, 10:25 AM
This is how I did my current project, epoxy prime and Raptor on the bottom before starting bodywork on the top...give me another two years and Ill know if it was a mistake
Jeff-
The Following 2 Users Say Thank You to Ketzer For This Useful Post:
03-03-2021, 11:34 AM
I have a somewhat different process. All metal work done, then rotisserie, then media blast all non exterior flat panels which I strip by sanding, then 3 coats epoxy primer whole shell, then bedliner, then filler work within epoxy recoat window, then epoxy, then poly primer, then block entire car, then urethane primer, then block whole car 180 through 400 then ready for epoxy sealer and paint.
Your method will work, it’s just that some metal work is best done with the car properly supported and not on a rotisserie. It is also a bit tougher to keep the bedliner looking good.
Don
The Following User Says Thank You to dhutton For This Useful Post:
03-03-2021, 11:54 AM
did my underneath first
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - Speedtech Extreme Subframe/Torque Arm, LS3/4L80E, 19x12/18x10 Budniks
The Following User Says Thank You to patriot68 For This Useful Post:
03-03-2021, 06:31 PM
Thanks all.
Don, thanks, I've been wondering about removing from rotisserie to complete. You may have seen my car on IG (jarhead1017). Working on the Speedtech install now, had to remove part of the trunk.
03-03-2021, 07:08 PM
Originally Posted by jarhead
Thanks all.
Hi Joe. I’ve been following your build and Gunny.  Sometimes depending on the build I’ll put a shell on the rotisserie twice. Once you do it the first time it doesn’t take too long to put it on the rotisserie a second time.
Don
03-04-2021, 06:19 AM
My process: - Media blast to strip and see all the issues
- Epoxy primer bomb entire car
- Metal work
- Finish rest of the custom changes/do full mock-up
- Body work entire car, starting with bottom and secondary areas like inner finders, etc.
- Final paint bottom, secondary areas, interior, jams
- Final paint top
This way you don't have to stress about any finished paint while you are doing mock up and it makes the paint setup/prep grouped together.
The Following 2 Users Say Thank You to RDuke For This Useful Post:
03-11-2021, 05:55 PM
If you live in a low humidity climate, then I would leave bare metal until all metal work is completed. If not, I would finish floor, then epoxy prime only. Then finish all other metal work and then prime, followed by seam seal and bed liner on floor.
Jay
The Following User Says Thank You to Jay Hilliard For This Useful Post:
03-11-2021, 06:10 PM
joe .. my two cents.. I wish I had done my Differently.. wish I had done the entire mock up .. console... seats, seat belts exhaust all of if..
i pained and then rhino linered my floor bottom.. then has to work around it to weld in bungs and brackets..
The Following User Says Thank You to XLexusTech For This Useful Post:
