Old 03-22-2021, 02:37 PM
camcojb camcojb is offline
Default When you hear funny noises....
don't ignore them. My 4 post lift had started to make a funny popping sound occasionally when being lowered. I decided to check it today and found this...
Old 03-22-2021, 02:39 PM
As close to breaking as you can get without actually breaking. This is one of the main two pulleys off the ram itself.
Old 03-22-2021, 03:38 PM
WILWAXU WILWAXU is offline
Yikes!
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
The Following User Says Thank You to WILWAXU For This Useful Post:
camcojb (03-22-2021)
Old 03-22-2021, 03:51 PM
go buy a lottery ticket ..holy S#!T
The Following User Says Thank You to raustinss For This Useful Post:
Old 03-22-2021, 07:34 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Dayum. I'm going over my two post first thing tomorrow!
The Following User Says Thank You to Ketzer For This Useful Post:
Old 03-22-2021, 08:20 PM
When I started looking for replacement parts I noticed the assembly date on the serial number tag... 04/2001. So I've had this lift for 20 years, and I use it a LOT and my friends use it a LOT lol. Been a great unit, did replace the ram a year or two ago for a slight leak that couldn't be fixed locally, other than that it's been flawless. I checked all the pulleys then and either missed this one or it failed after.
Old 03-23-2021, 01:29 AM
AMSOILGUY's Avatar
AMSOILGUY AMSOILGUY is offline
Whew that's crazy. When I had a 2 post lift installed a couple years ago a friend who owns a repair shop said to check the anchor nuts often. I have on 2 occasions found more then 1 nut loose enough to twist with my fingers. Huge pucker factor. Nice catch!
[email protected]
www.jacobehlers.com
The Following User Says Thank You to AMSOILGUY For This Useful Post:
camcojb (03-23-2021)
Old 03-23-2021, 07:40 AM
BMR Sales's Avatar
WOW!
I just had my 4 Post serviced for the 1st time in 15 years a couple of months ago. Had to replace the Ram, Hoses but nothing was broken.
You got lucky on that one
Old 03-23-2021, 02:18 PM
SSLance's Avatar
SSLance SSLance is offline
My 4 post is squeaking when I lower it now... I think it'll be alright but will be sure to keep listening closer...
Lance
The Following User Says Thank You to SSLance For This Useful Post:
Old 03-23-2021, 05:07 PM
jarhead's Avatar
jarhead jarhead is offline
glad you are OK, that looks bad
joe
Semper Fi
My 68 Torino
The Following User Says Thank You to jarhead For This Useful Post:
