Old 03-30-2021, 09:22 AM
71 RAT's Avatar
71 RAT 71 RAT is offline
Default BBC A body GM Oil Pan
For the guys here running a BB, probably not many! What oil pan are you using? With our suspension modifications can we corner hard enough that a stock pan is not sufficient ? I picked up a decent Milodon Pro Touring/Road Race pan. As usual Murphy's Law is consistent. My drivers side header seriously interferes with the kick out. Only 1 3/4" tube diameter. Was hoping to sell, it but no luck so far.
71 SS 454 TH400 2.74 1st gear GV Overdrive 3.55 Gear SC&C Stage 11 QA1's 4 Wheel Baer Brakes AGR Box Straub SR .630 .612 lift 240 256 [email protected]
83 K20 454 TH475 NP 205 Dana 60 Track Lok Detroit Locker Rear
58 Ford 821 Powermaster Loader Backhoe Restored Family Heirloom
Old 04-04-2021, 09:55 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
Milidon 30955 oil pan is what I used on a 572ci BBC in a 68 Camaro.
Fitment with 2” primaries is perfect.
It has kickouts but less aggressive than your pan.
I hammer this car via autocross and spirited driving without a single oil pressure drop.
Another option could be to cut your pan and reweld more clearance.
Sorry you haven’t got more responses.
BBC’s rule!
Old 04-04-2021, 12:57 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
I would talk to Milodon .Moroso and Canton for help.
