Old 04-16-2021, 08:04 PM
ModernMuseum ModernMuseum is offline
Default Hooking relays to Electric Life Power Window Kits - 69 Firebird
I have a set of crappy Electric Life window units in my 69 Firebird all around. I know the Nu Relic units are a lot better from what I've read. My windows don't roll up very well and drop crazy fast when rolling down.
However, a more economical fix might be to hook the switches to relays to get more power to the window motors. Has anyone done this? Is it worth it?
Anyone have a diagram of how to do this?
Old 04-17-2021, 05:25 AM
dhutton dhutton is offline
Where are you getting the power feed? I find that you get better performance if you run the feed with a heavy gauge wire directly to the battery to minimize the voltage drop. It also helps a little if the car is running.
Don
Old 04-18-2021, 08:08 AM
Not sure; I'll have to check. Are you running Electric Life window kits?
Looking at the Nu Relic kits, the harnesses / switches don't look any beefier than the ones I have. I am thinking I can get buy with upgrading the motor/gear units and keeping my existing wiring harnesses/switches.
Old 04-18-2021, 08:54 AM
The wiring is inadequate in both kits imho. I use NuRelics and run power to the battery with a large gauge wire.
To verify wiring simply put a voltmeter on one of the motors and measure the voltage. In theory it should be close to the battery voltage.
Don
Tags
electric, life, power, windows
