Old 08-19-2021, 07:28 PM
unrulyprocuda's Avatar
unrulyprocuda unrulyprocuda is offline
Default 1968 Plymouth GTX Convertible protouring
Item Location (City/State):Evansville Indiana
Price: $52,500.00
Description:
Originally a 1968 Sport Satellite Convertible 383 super commando automatic console bucket car Factory B5 blue Black Interior Black Top car
Owned for 18 years
when i purchased it had new paint new carpet new bumpers and the Gtx Tribute was started with Emblems Grille and Hood
i drove the car for many years when the motor went south
Cleaned and painted engine compartment b5 blue
cleaned and powder coated K frame and professionally rebuilt with poly graphite bearings new upper tubular and lower control arms and new spindles
in 2012
i sent the car to Spanky's rod shop in Mena Arkansas for a Professional Hemi swap he installed low mileage 5.7 from a 2006 300c it had 2500 miles on it
Mark at spanky's took around 8 months to do the Install
using all new parts he painted and installed the entire thing very professionally done install couldn't of been happier
New in the rebuild was these and many other new parts
TTI headers,
Stainless tank,
Wiring harness,
Ecu,
Motor mounts,
Fly by wire,
TTI adaptor for 727 transmission
New Aluminum Radiator
new Fans
Manual steering box
new fuel lines
new balanced Driveshaft
new trans crossmember
new Alternator
new Transmission lines
new 727 transmission with new 2800 stall convertor
new coil packs
cleaned painted and hid all wiring in engine compartment
Flaming river tilt column and Grant steering wheel
few years after the swap
we did 13" dr diff disc brakes all around
new green bearings
new yokes for driveshaft
swapped the 323 sure grip out for 273 single for highway flying
the sure grip and new axles and new brake pads with new rotors come with the car.
new kenwood stereo system with subwoofer and amp blue tooth capabilitiesnew Budnick 20x12 and 19x9 wheels with nitto nt555 meats this is the widest tire you can get with stock rear-end and tubs the car is not modified
added the wing for protouring look
Installed Redline lumtronics Headlight halos not currently hooked up.
Build was about 9 years ago still runs and drives excellent i wouldn't hesitate to fly in and drive home to California or any long distance trip
it is great on the highway 22mpg at 90mph
things that need fixed (just being picky)
Passenger inside door latch dont work
there is a small split in the metal inside the drivers door area
minor paint bubbles scratches and small dings evident but overall killer car
few rips in the Top where the ribs are 99% of the time its down has a perfect top boot
brakes need new supplied rotors and pads installed
Drive, Restore or Hellcat replant would be easy already has motor mounts computer ready to go
Located Southern Indiana Delivery possible open title and ready for new home
Tags
gtx, hemi, mopar, plymouth
