Old 09-21-2021, 08:04 PM
sigourneyanderson sigourneyanderson is offline
Default Pro-Touring Car Los Angeles Area
Ultimate Shark Apex Uplight Vacuum Review
If you are looking for a vacuum cleaner that is both compact, handy, and high-performance to handle any harmful agents such as dirt or pet hair, the Shark apex uplight corded lift away vacuum cleaner is the right choice.
Because this product from the Shark brand is the perfect combination of a powerful engine and a unique vertical design, thereby giving users a quality vacuum cleaner model that anyone, old or young, can efficiently operate.
Dimensions and weight
Size and weight are one of Shark apex vacuum highlights compared to other vacuum cleaner products on the market. With dimensions of 46.19 x 10.44 x 11.38 inches, the device is suitable for users to use without having to bend their back too much.
The balance between factors such as length and height allows us to easily store the device in tight corners of the house instead of taking up extra space for storage.
Despite its impressive size, this vacuum cleaner model weighs only 10.7 pounds, a number much smaller than similar products. That's why manipulating the device will become lighter and more straightforward.
Construction quality
To both reduce the machine's weight and ensure long-term durability, the manufacturer has used hard plastic as the primary component material of the Shark apex uplight lift-away duoclean. Although not possessing the same resistance as metal materials, the hard plastic part can still resist shocks and protect the stability of the machine's operation.
Although not made of high-class materials, in return, this vacuum cleaner possesses details with an exact level of machining. Each part fits together in an awe-inspiring way, thereby minimizing breakages during operation.
Operational performance
Shark apex vacuum cleaners are extremely impressive, especially on soft surfaces such as carpets or hard floors.
With the built-in HyperVelocity Suction technology, the device can easily create super-strong vortex-like airflows to suck up any harmful agents on their way into the container. That is why fur, one of the most challenging wastes to suck, cannot escape from the machine's nozzle.
To handle hard surfaces like floors well and HyperVelocity Suction technology, the machine also uses DuoClean Dual Brushrolls to optimize cleaning performance. With two sweeping brushes with different designs, we can suck up even the smallest dust particles or get stuck in the floor gaps without too much difficulty.
Accessories and assemblies
The manufacturer does not include Shark apex uplight vacuum too many auxiliary tools like many other similar products. If you open the box for the first time, you will also see most of the components of the vacuum cleaner, such as the body and the suction tube. Meanwhile, special brushes or nozzles only have about a few items. So if you want to use many different types of accessories, you can only buy more outside.
The process of assembling the device is not complicated, but there are two points that you should note that the vacuum tube part can be a bit difficult to make, and there will be a lot of different components. These two issues will get in the way if you don't pay attention.
Look at Shark Apex uplight corded lift away review, it can be said that this vacuum is the right choice for you to clean your beloved home in the simplest and fastest way.
Old 09-21-2021, 09:00 PM
232_ray 232_ray is offline
I haven't found one yet. sorry
Old 09-23-2021, 03:42 PM
Roscoe03 Roscoe03 is offline
If you're okay with traveling about 1.5hrs North of you.
https://ironworksspeedandkustom.com/
Old 09-28-2021, 10:52 AM
ScotI ScotI is offline
They're worth that drive.
