Old 10-23-2021, 10:01 AM
mc1984ss mc1984ss is offline
Default Help with adding breather to cast GM perf parts valve covers
I have a set of Cast GM performance parts valve covers for my BBC. The dreaded time has come to drill a hole for a breather. Anyone have any recommendations for a breather? As of now I was planning on drilling a hole and using a grommet that has the baffle molded into the rubber with a push in breather. I'm open to suggestions especially from anyone that has done this before. Thanks in advance
Old 10-24-2021, 09:10 AM
Bad Bowtie Bad Bowtie is offline
mc1984ss,
I understand the hesitation on drilling holes in $800.00 valve covers. I carefully measured out to get an area that wasn't in direct line with the rocker arm to reduce oil splash into the breather. I used an open hole grommet but fabbed my own baffle out of thin aluminum making sure it wasn't to close to the hole to allow oil to flow freely into the engine. I used panel bond adhesive (the body shop stuff not JB weld) to attached the baffle to the valve cover because I didn't want to weld to the covers. Though I had some photos of the underside but can't find them now. Its really not that hard after you punch the hole
BB
The Following User Says Thank You to Bad Bowtie For This Useful Post:
camcojb (10-24-2021)
