Old 01-12-2022, 03:45 AM
jp455 jp455 is offline
Default 73 Firebird trunk mounted fuel cell
Hello all...Im toying with the idea of a trunk mounted fuel cell sitting on the floor, not with the floor cut out.
If anyone is running one, what size did you fit?
Manuel Scettri
www.hydynemotorsport.com
Old 01-14-2022, 09:46 AM
Perry Mitchell Perry Mitchell is offline
I suggest you make your own like I did. It fits in the well of the trunk without any sheet-metal removal. My tank holds 26 gallons of fuel. Sorry for the sideways pictures.
The Following User Says Thank You to Perry Mitchell For This Useful Post:
camcojb (01-14-2022)
Old 01-14-2022, 10:30 AM
Tinker's Avatar
Tinker Tinker is offline
If you go this route, make sure you have a complete closeout panel between the trunk and cabin. I personally get a little squeamish when I look at power accessories and batteries right next to a fuel cell.
In the performance world, the tank up in the trunk also places all the weight at that much higher of center of gravity
Chris
Old 01-14-2022, 06:02 PM
The tank in my car does not have a vented cap. It is vented to the outside of the car through tubing that exits behind the bumper. The total height of the tank is less than 6'' high and the car sits low so I am not concerned with the center of gravity. The bracing behind the rear seat is completely sealed of with welded in panels. The tank is fabricated with 3/16'' aluminum and is totally baffled. I feel it is safer than a sheet metal tank hanging under the car.
Old 01-14-2022, 08:35 PM
Tinker's Avatar
My comments were not by any way a dig on your vehicle. They were merely points to think about in the discussion. I am glad you detailed your installation further. Through your pictures and description it looks like it is a very well thought out and executed installation.
Chris
Old 01-15-2022, 09:05 AM
Thank you. Your comments were not taken as a dig. I merely wanted to ad to my installation and to respond to your comments. Again thank you.
